Jarvo
Message 1 of 6
(Whole Home Wifi) Guest Network - No Internet
Hi All
Wondering if anyone can help, quite simply, users can connect to the guest network, but not access the internet at all.
Spideysenses are suggesting that they cannot perform DNS resolution.
---setup---
Router - SkyQ Hub
Raspberry Pi - Running PiHole, for advert blocking, and also DHCP / DNS server for the network.  DNS requests are then forwarded to CleanBrowsing.org (to ensure the kids have safe-search, and block dodgy sites!)
6 x BT Whole Home WiFi Disks - Each with dynamic IP, I didn't see the need to fix their IPs ... but can if needed.
It has been working when initially installed.  But as I don't use the guest network, it was only today when one of my clients said "I can't get onto the internet", did I realise there was an issue!
Thanks in advance for any help or advice on this one.
5 REPLIES 5
Dean007
Recognised Expert
Message 2 of 6
Re: (Whole Home Wifi) Guest Network - No Internet
Hi @Jarvo
If you still have not been able to resolve the connection issue, it maybe worth having a chat with the BT Whole Home Team..
BT Whole Home Product Helpdesk
You can contact the Helpdesk on 08081006116
Mon-Fri 9.00am to 5.30pm Sat 9.00am to 2.00pm or contact them by email at btconnectedhome@bt.com
Dan-O
BT Devices Expert
BT Devices Expert
Message 3 of 6
Hi @Jarvo
I'm assuming based on your setup that your DNS/DHCP server is a different IP address from the gateway/router?
If so, there is a known problem with the Guest network in this configuration. We already have a fix and will include this in the next software release.
In the meantime, are you able to run your network with the router/DNS IP the same? Either by moving this back to the Sky Q Hub or installing appropriate software on the RPI to function as a router?
Thanks,
Dan-O
Jarvo
Message 4 of 6
Hi Dan-O
Indeed, the RPI is on a different IP address.
That was my suspicion, that the Guest network couldn't see the DNS server due to device separation etc.
I'll keep an eye out for the next software release. They seem to be fairly regular! 🙂
Thank you both for your swift reponses.
thudandblunder
Message 5 of 6
Hi
I have a similar problem but with the guest network hitting a proxy server. Is there a tech document which lists what's blocked at the guest level plus also is the dns fix now live and if so what's the fw level.
shaunmpond
Message 6 of 6
Same question here...
