jimbg
Message 1 of 3
Whole Home Wifi factory reset and reinstall from 2 different packs
I originally installed a 3 pack system and added another pair later.
That all went well and has been running for 7 or 8 months. It has had various problems and now I want to reset all the devices and do a clean install, updating the firmware at the same time.
Is there an easy way to decide which were the 3 original disks? Presumably the they have the samre details on the back?
I am not on site at the moment and when I do arrive I would like to carry out the reinstall as quickly as possible.
Cheers
Jim
2 REPLIES 2
B1998
Message 2 of 3
Re: Whole Home Wifi factory reset and reinstall from 2 different packs
Yes, if you bought a 3-pack and a 2-pack then you should see 3 discs with the same details on the back label and 2 other discs with the same details between each other but different from the first three.
jimbg
Message 3 of 3
Thanks, that will make it easy when I do it.
