js25
Message 1 of 12
Whole Home - mixed wifi and ethernet connections
Hi,
I have 4 whole home discs, which i'm trying to set up as follows:
Disc 1 - Ethernet connection to TP Link Router
Disc 2 - Ethernet connection over powerline connection to TP Link Router
Disc 3 - Wireless connection
Disc 4 - Wireless connection
On the app it appears i have two separate networks, each containing one of the Ethernet connected disks 1 and 2, with the wireless connected discs being connected to either disc 1 or disc 2. All the discs appear on the app, but the ones on the "other" whole him network are shown in red, with a connection problem. If i use the web UI on my macbook, it only shows the disc(s) in in the particular whole home networks I am connected to (although I am having problems with my macbook connecting at all, since the December firmware update, which i am trying to resolved on a different thread!)
Disc 1 and disc 2 are on different wifi channels, with discs 3 and 4 being on the same wifi channel as the ethernet connected disc in the same whole home network.
Is this how it is supposed to work now, or is there a way to get all the discs on the same network? I have previously managed to have this working before the December firmware update.
11 REPLIES 11
BT Devices Expert
BT Devices Expert
Message 2 of 12
Re: Whole Home - mixed wifi and ethernet connections
Hi @js25
I'd suggest you factory reset the disc that is on different Wi-Fi channels (you mention 3 and 4 are on the same channel as the Ethernet disc) as this means it is not synchronised with the rest of the network.
Ensure the disc is plugged on and connected to Ethernet, with a solid blue LED. Then press the reset button for 1 second, the LED will go off then solid purple. Once it has rebooted and gone blue you should see a flashing purple LED after 15 seconds or so.
You may wish to remove the disc from the app and re-add again when doing this.
Device expertDanO
Show your appreciation!
Kudos”Kudos”
js25
Message 3 of 12
Hi @Dan-O
I've done the factory reset on disc 2 (the one connected to ethernet via a powerline adapter), got the flashing purple LED, then removed the existing disc in theapp (shown in red as offline), and then added it as a new disc. It showed up fine in the app, but my other 3 discs were now showing as offline in red. (This disc is in the attic where the study is).
When i go downstairs in range of the other discs, the app just shows these 3 discs, and nothing for disc 2. I tried adding disc 2 again when i was downstairs but just get the message "unable to detect new disc".
However all 4 discs are working on the same wifi channels for both 2.4GHz & 5GHz.
BT Devices Expert
BT Devices Expert
Message 4 of 12
Interesting - which model of Powerline(s) are you using?
Some models do not pass multicast traffic properly, which blocks the disc to disc discovery protocol and will make them appear to be missing on the app.
Device expertDanO
Kudos”Kudos”
js25
Message 5 of 12
I'm using TP-link AV 1200 powerline adapters (with the wifi off).
BT Devices Expert
BT Devices Expert
Message 6 of 12
As you're not using the Wi-Fi - can you try swapping the Powerline units round to see if this makes a difference?
Also are you able to directly connect this disc via Ethernet to check (just to rule out any other issues)?
Device expertDanO
Kudos”Kudos”
js25
Message 7 of 12
Hi @Dan-O
Swapping the Powerline units didn’t make any difference. However connecting directly to the router the disc worked fine and showed up on the network.
John.
js25
Message 8 of 12
Hi @Dan-O
I've just done a firmware upgrade on the powerline adapter, which has solved the problem - all 4 discs now showing as connected. Thanks for pointing me in the direction of checking out the powerline adapter!
Prior to this I also disabled IGMP snooping on my main TP-link router - I'm not sure whether this helped or not, but I've left it disabled.
John
BT Devices Expert
BT Devices Expert
Message 9 of 12
@js25 wrote:
Hi @Dan-O
John
Excellent news - thank you for the update. Glad you're all working now.
Device expertDanO
Kudos”Kudos”
grahaml
Newbie
Message 10 of 12
My system shows the same...each Ethernet connected disc generates a wireless network and in the app if your connected to one network the other discs show red and vice versa. It looks like an app problem and also the web browser only shows the network for the disc you’re connected to so it seems the system doesn’t show networks radiating from the hub it seems to work backwards from a disc ....it all seems to work ok though, just not what one expects.
