Message 1 of 3
Whole Home wifi signal interfering with Wireless CCTV
Hello,
I'm a new Whole Home wifi customer and linking the Discs to a new Sky router.
The system works resonably well but, the wifi sgnal from the discs is interfering with a cctv camera that has it's own transmitter and receiver.
Any ideas on how to fix this issue would be appreciated?
Thank you,
Tony
2 REPLIES 2
Message 2 of 3
Re: Whole Home wifi signal interfering with Wireless CCTV
Any ideas would be very appreciated?
is it possible to edit / modify channel settings etc operating on the Disc?
Tony
Message 3 of 3
Which CCTV system do you have and how does it work?
You can change the channel at http://mybtdevice.home but if the camera is not Wi-Fi, you may not be able to avoid the radio interference.
