lmellman
Newbie
Message 81 of 86
Re: Whole Home with more than 3 discs
I have quite a large area to deal with but I do have 7 discs all with blue lights. The WH iPhone app only seems to be capable of showing 6 discs but if I go into the router home page I can see that 7 discs are connected. Or am I mistaken about the 7th disc working properly?
engelbertink
Message 82 of 86
I think it’s a limitation of the app. In the past it was 3...
Message 83 of 86
Please could i be notified if/when theres a solution, and more than three discs can be added?
I've got exactly the same problem, i need wifi in an outbuilding.
aubreyd
Message 84 of 86
john lewis sell a 4 pack kit
B1998
Message 85 of 86
6 discs are supported already.
lnajr02
Message 86 of 86
Please check out the FAQ page you can have a max of 6 discs connected, mesh working will only work to this maximum. If you have purchased more than one kit you will have to add the additional discs one at a time using the app. Just because you get a blue LED doesn't confirm it's one network.
Tip: if you have a set of three and would like to add additional discs, factory reset the additional disc with the Ethernet cable connected to the Hub with Disc one still connected, then power down the additional disc and follow the App. I have 5 connected with no problem.
