Meerkatdawg
Message 1 of 4
Whole home Wifi Device Names
Hi.
I'm wondering why all of a sudden I can now no longer rename devices. I'm met with a blank screen when I try and nothing seems to work. Is this a known bug at the moment?
3 REPLIES 3
BT Devices Expert
BT Devices Expert
Message 2 of 4
Re: Whole home Wifi Device Names
Hi @Meerkatdawg
Are you using iOS 12?
Dan-O
Meerkatdawg
Message 3 of 4
Hi Dan-0
Yes, correct first time. Which would coincide with the problem rearing its head. So just hold on for an update?
At least I know and it won't drive me mad now. Thanks for your help!
BT Devices Expert
BT Devices Expert
Message 4 of 4
Hi @Meerkatdawg
Yes - there is a known issue we found during the iOS 12 Beta releases, which is likely to impact the formal release as well. I've created a post here: https://community.bt.com/t5/BT-Devices/Whole-Home-Wi-Fi-App-with-iOS-12/td-p/1880482
I will publish on that thread when we have a confirmed release date for the new app.
Dan-O
