JMB
Expert
Message 1 of 2
Whole home Wifi - I presume they all interconnect by WiFi
Just looking at the advert from BT for Whole Home WiFi.
I presume the "discs" interconnect using WiFi - I would not have one of the power line connection systems in the house because of the interference they generate.
Do you log on to the system and the connection last wherever you move in the house without having to switch?
By the way, when I searched here for "whole home wifi" I got this response
"Did you mean: whole home wife"
MB
1 REPLY 1
tsr2
Message 2 of 2
Re: Whole home Wifi - I presume they all interconnect by WiFi
Interconnection can be via wifi, ethernet or a mixture of the two, depending on your preferences and the requirements of your environment.
In normal operation the WholeHome should connect to the disc with the best signal and swap seamlessly between discs as you move around
