Thomo61
Message 1 of 4
Whole home Wifi
What iPhone Ap do you need? As cannot fine one called whole home wifi which the box implies ?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Whole home Wifi
Hi @Thomo61,
Welcome to the community forum.
Take a look at - How can I download the Whole Home Wi-Fi app?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 3 of 4
Re: Whole home Wifi
@Thomo61
The App itself is call BTWholeHome
PaddyB
Kudos”
Thomo61
Message 4 of 4
Re: Whole home Wifi
Cheers
Not impressed so far. Doing some impirical tests tomorrow
