Jjbur
Message 1 of 2
Whole home not working
Hi new here and looking for some help.
I have three whole home discs that have worked mostly fine for the last 18 month but last week I could not connect to them anymore. I have tried switching them off and on, tried resetting, tried resetting my sky router, tried a new Ethernet cable , plugging them into a different port on the router and have tried all three discs individually and they all do the same thing. They will switch on turn purple then then go into the blue flashing then the slow blue flashing for a few hours then go solid blue when I try to connect the network it either cant find the ip address or check ssid. I imagine this can only be a software issue as I wouldnt have thought all three dics would break at the same time.
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: Whole home not working
@Jjbur Welcome to to community and thanks for posting, that doesn't sound good. Did you do a factory reset by using a pin or paper clip to press the Factory Reset button on the back of the disc?
