Message 1 of 2
Whole home wifi
About to set up whole home WiFi discs. My current modem is the new BT Smart hub and I will link the first disc to that.
I currently have 2 devices linked to the existing hub by Ethernet cable. One is to my Sky Q box and the other to a central heating modem.
The whole home disc has only 1 ethernet port and that will go to the Smart hub. How do I link the Ethernet cables to the other devices? Will they still work if I leave them plugged in to the Smart hub or should I use a splitter to connect them to the new whole home disc?
1 REPLY 1
Message 2 of 2
Re: Whole home wifi
Hi @rdec1945, thanks for your post about the WHW setup and, sorry you got no replies. Check out the relevant Whole Home Wifi product and if you still require assistance the phone number and email address for the product helpdesk are listed and they'll be happy to help you.
cheers
John
