midlife
Message 1 of 2
Whole wifi firmware v1.02.05 build 1 update
as requested have uploaded this firmware though didnt seems to work properly in that I did the update but it said I was disconnected and to go to settings and rconnect then come back to app. I did that went back and it said I had uploaded this firmware. Hope it is ok
Graham
1 REPLY 1
Darren_B
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: Whole wifi firmware v1.02.05 build 1 update
Good morning midlife,
To complete the firmware installation, the Discs will automatically reboot/restart themselves, which will temporarily disconnect your wi-fi devices.  The message you recevied is just to inform you of this disconnection.
Everything should be working as expected.
Regards
Darren
