Message 1 of 2
WholeHome Disc Compatability
I happily have four discs working well but would like another for another room. In the admin area I can only see they are hardware version "01" (the old logo on the front). It's not mini or premium its the original version.
Before purchasing another normal white big disc are the new version the same - just a different logo on the front?
1 REPLY 1
Message 2 of 2
Re: WholeHome Disc Compatability
Yes, there is no difference between the old and new logo versions - as long as you stick with the same model (Whole Home Wi-Fi 1st generation), that will work fine.
Dan-O
