Message 1 of 6
WholeHome WiFi Web Interface and App are not working
I have recently moved house and since then the web interface/app have not worked at all. The actual devices are working and I have WiFi across the house. But I would like to add an extra disc to my setup to increase coverage due to our new place being bigger.
App
The app suggest I am not connected to the discs despite this clearly not being the case. I have uninstalled, reinstalled the app a few times (I am using iOS).
Web Interface
Whilst I can login fine, I cannot see any information such as the discs or devices connected. I can see information on the System -> Firmware Update tab.
Steps taken:
- Login to http://mybtdevice.home/index.htm
- Try to access Overview, Discs or Devices
- Unexpectedly only displays a blank gray box with no information.
I have tried powering down the discs and only connecting the master disc.
What steps can I take to try to resolve the various issues so I can add the extra disc?
Firmware: v1.02.12 build02
Tags (1)
5 REPLIES 5
BT Devices Expert
BT Devices Expert
Message 2 of 6
Re: WholeHome WiFi Web Interface and App are not working
Hi @glosrob
This doesn't sound right - please can you e-mail the helpdesk at btconnectedhome@bt.com to register an issue?
They will forward your issue to us in 2nd/3rd line support and we will be able to diagnose your issue further.
Thanks,
Dan-O
Message 3 of 6
Thanks - I will do that now.
Newbie
Message 4 of 6
Hi Glosrob,
I'm also experiencing the same issue. Were you ever able to resolve this issue?
Message 5 of 6
Sort of..
I never got the phone app working. But in the end I didn't need it so gave up.
The web interface worked once I did the following:
- disconnected all discs (removed power cable)
- factory reset each disc
- reconnected the primary disc only
- ensured primary disc powered up and connected ok
- loaded web interface to check all was good again
- added other discs afterwards
After that, the web admin interface worked fine and I was able to add an additional disc without the phone app by connecting it via ethernet cable.
Newbie
Message 6 of 6
Thanks so much for the reply, this is great.
I will give it a try and hopefully I'll get the same results.
