agaskew
Message 1 of 2
WholeHome Wifi App does not work
I've had WholeHome for about 3 years, and its working OK.  The Andoid app however....is a bit of a disaster.
I had to delete and reinstall the app.    Any attempts to get it connected and working result in "- Error code: Setup-012"  or an infinite loop of retrying.
Discs are on v1.02.12 build02
Hopeless!  Any ideas?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: WholeHome Wifi App does not work
Hi @agaskew  sorry that you are having an error when trying to use the WHW app.
Give the WHW helpdesk a call on: 0808 100 6116 (Mon to Fri 9am to 5.30pm and Sat 9am to 2pm)
Or drop them an email with your details to: btconnectedhome@bt.com They will be best placed to help fix this for you.
Cheers
John
