Antipole
Message 1 of 2
WholeHome hub non-optimal connections
I have a three disc WholeHome set-up:
(1) Study - with ethernet connection to router
'Good' connection to
(2) Lounge
'Excellent' connection to
(3)Upstairs
Disc 3 connects to disc 2 with excellent connection.
Disc 2 connects to disc 1 with 'good' connection only and suggestion for improvement.
It works OK.
However, devices in the Lounge connect to disc 3 upstairs, even though they are much closer to the disc in the same room.  Does anyone know whether a disc is chosen on the basis of its onward signal strength?  If so, then the lounge devices are choosing 3 rather than 2 because it has an 'excellent' connection.  However, the internet connection from disc 3 is via disc 2 and the only 'good' connection to disc 1.  It would be more efficient/faster if they connected to disc 2.
Any advice?  Thanks.
1 REPLY 1
ukoberon2
Message 2 of 2
Re: WholeHome hub non-optimal connections
Watching - have a similar issue.
