Prycop
Message 1 of 3
Wholehome App connecting to a current working setup
Hi,
My system is up and running with my own SSID set up for Smart Hub and two disks.
When I launch the Wholehome app it greets me with a brand new setup scenario ie. asking to scan QR code etc.
Is there a way to get the App to speak to the disks that’s already up and running?
thanks
2 REPLIES 2
BT Devices Expert
BT Devices Expert
Message 2 of 3
Re: Wholehome App connecting to a current working setup
Are you using black Complete Wi-Fi discs?
If so you need to use the My BT app. The Whole Home app is for Whole Home Wi-Fi and won't work with the Complete Wi-Fi black discs.
Device expertDanO
Show your appreciation!
Kudos”Kudos”
Prycop
Message 3 of 3
Ah - that's where I've been going wrong.
Thanks for the help.
