Message 1 of 4
Wholehome Guest Security
Hi,
I'm looking into enabling the guest network on my Wholehome WiFi. It is set up, but the network does not have any advanced security on it (AES or WPA2/3). I haven;t been able to find out how to enable it. Any pointers much appreciated.
Thank you
3 REPLIES 3
Message 2 of 4
Re: Wholehome Guest Security
@RobertOz
Welcome to this user forum for BT Retail phone and broadband customers.
It would be best to give the WHW product helpdesk a call on 0808 100 6116 ( Mon to Fri 9am to 5.30pm and Sat 9am to 2pm) or drop them an email to: [email protected] and they'll be happy to help.
Message 3 of 4
Thanks Keith.
They were very helpful on the phone; the answer was to use the app to find the IP of the main WiFi Disc, connect to that using the ADMIN password. Once in the Configuration panel you get more options than in the mobile App, and can select the guest network to enable WPA2 (default was none). Set a password and all is good.
Cheers
Message 4 of 4
Excellent 😀
