I'm in the process of leaving one ISP for another so have a new hub from that company. Will I be able to simply plug in my BT Wholehome to the new hub or will I need to reset all the discs and install the network again? My gut tells me I shouldn't have to, but as you have to plug the discs into the router in the first instance I am dubious.
Thanks four your help
Solved! Go to Solution.
@robmartin22wrote:I'm in the process of leaving one ISP for another so have a new hub from that company. Will I be able to simply plug in my BT Wholehome to the new hub or will I need to reset all the discs and install the network again? My gut tells me I shouldn't have to, but as you have to plug the discs into the router in the first instance I am dubious.
Whole Home Wi-Fi will work if you just swap out the router and reconnect the new one - all devices will get a new IP address from the new router. If you want to have a completely clean setup you can reboot the discs after setting up the new router.
Dan-O
