Gdotp
Message 151 of 399
Re: Wholehome firmware v1.02.05 build 01
I hope your experience is better than mine was. The Decos stayed up but we found the connection was inconsistent. The kids with gaming kept saying their ping speeds varied a lot. As a result I sent them back to amazon and reinstalled the BT discs.
Jim-lad
Expert
Message 152 of 399
@tsr2wrote:
@Jim-ladwrote:
@tsr2wrote:
The Deco discs turned up today and, as soon as everyone else was off the network, I unplugged the BT kit and set up the Deco. First impressions are that the design isn't as nice as the BT kit and the app is horrid. The $64 milion question is whether it will prove more reliable. If it does, I will forgive it. If not, it will be back to the Homeplug kit.
Well you should be all set to post on the TP-Link forums now.  I've had a quick browse on there and noticed posts about disconnetions and disks turning red.  It will seem like a home from home.
Best of luck.
The BT Wholehome kit has exhausted my patience for unreliable kit. The TP-Link has to be more reliable or it 's for the chop very quickly. I won't be hanging around the TP-Link forums looking for workarounds and hoping for fixes. As the BT kit is better in most respects, the only reason for keeping the TP-Link would be better reliability.
It's a real shame, the BT kit as it was when I first got it was just what I needed and I recommended it to a few people, but since then my confidence in it has been completely destroyed.
Apparently some users of Deco are currently reporting issues with their new firmware - sound familiar?
I'll keep everything crossed for you.
dgilbert2
Expert
Message 153 of 399
@tsr2post back when you have been using the Decos for a couple of weeks. From reviews they seem to have similar issues so would be interesting to hear how you get on.
Richard747
Message 154 of 399
After four days on v1.02.05 build 01 WH seemed to have settled down, with even the iPad connections moving around the house without issue. Then it fell over this morning. All Wi-FI connections failed, not just the usual iPad and other iOS devices. The TomTom 6200 satnav was downloading a multi gigabyte update and that failed part of the way through. It went into a ‘waiting for IP address...connecting...connected...waiting for IP address’ loop. The Ethernet connected devices continued function normally. Then after half an hour or so of doing nothing it all started to work again.
Jim-lad
Expert
Message 155 of 399
@Richard747  sometimes a 'wait and see' policy can be the best option.  Perhaps many of us have a tendency to intervene at the first sign of something being amiss.
nigma
Message 156 of 399
I am having the same issues as before even after the upgrade to 1.02.05 build 01. I have two discs hard wired to my router and a third connected over wireless.
When only using the hardwired discs, stability seems to be ok (havent had it fail with wired only). It's only when I power on the third disc the whole network seems to go down after 1-2 days.
What's really odd is that it seems to take down all my wired devices too. The whole network seems to stop functioning until I power off all the discs and restart them. I would have expected only my wifi devices to stop working.
foz
Message 157 of 399
My WiFi back hauled disc has been pretty stable on this new firmware as yet, i have 4 x running Ethernet bh and this one i have as a test using WiFi bh, on previous firmware it failed almost every couple of days but on the odd occation it had stayed up for longer periods 1-2 weeks. time will tell but as yet its not been down since upgrade
Kitchen
Uptime: 6 days, 23 hours, 26 mins, 25 secs
Connection Status:Good
Connection Type:Wi-Fi (5GHz)
Signal Strength: -73dBm
BT Devices Expert
BT Devices Expert
Message 158 of 399
Hi dgilbert2,
Sorry to hear you're having problems with the new firmware release.
It would be helpful if you could email your logs to the product helpdesk  btconnectedhome@bt.com
and we’ll investigate and see how we can help.
Device expertMarkI
Show your appreciation!
Kudos”Kudos”
ishamm
Message 159 of 399
I am looking to set up an Ethernet backhaul on one of my hubs which has poor signal, using a tp-link powerline system. Can i do this by pluging one powerline into my homehub5 and the other into the poor-signal wholehome hub? or is it better to connect both to wholehome hubs? is it that simple?
foz
Message 160 of 399
"Can i do this by pluging one powerline into my homehub5 and the other into the poor-signal wholehome" Yes
