Message 11 of 399
Re: Whole Home WiFi firmware update v1.02.04 build10
@ICAltdwrote:
Just another BT fail maybe?
Spot on.
Message 12 of 399
@ICAltdwrote:
same here - via app -shows downloading and the reverts to update formware screen.
Since most users won't be aware of this today and auto updating occurs over night I can't beleive the server is overloaded.
Not saying your wrong but it may check for new frimware and download it then just install it in the early hours?
Recognised Expert
Message 13 of 399
@foz
It should allow manual updates as well as the auto updates. I would like to think its the servers being overloaded at the same time.
Message 14 of 399
mine now saying i have the latest firmware not showing an update ?
are you guys still seeing an update available, obviously i am still showing build 10
now downloading via mobile app !!!
Message 15 of 399
Just a thought... do you guys want to create a separate thread about wanting to update today manually, then you can continue discussion separately. This discussion is out of topic for this thread about Build 10. Think about someone coming to this forum first time for help. It just won't make any sense to them.
Then when someone has the update working they can create a new thread again about feedback on the new build which everyone is waiting for to confirm if it works well.
Message 16 of 399
Message 17 of 399
Re: Wholehome firmware v1.02.05 build 01
I am in no hurry as mine (fortunately after implementing suggestions from this forum) works OK.  However, it is only fair to note that when a major update is released for any large fleet of equipment, the associated servers usually struggle to cope in the initial period after the release.
Hopefully, people will consider this and be a little patient before getting too worked up and claimings it a 'fail'.
Message 18 of 399
If your manually downloading it, rather than select immediately try selecting the next hour, seemed to download then just waiting for 12pm on now for it to install will report back
says Upgrade scheduled for between 12:00 and 14:00.
Message 19 of 399
Mine has downloaded just now and master node says "Firmware update processing".....
Message 20 of 399
Joining thread to monitor progress, prior to jumping in
