jonwis
Message 1 of 3
Wi-Fi Extenders.
Hi,    Four years ago I started receiving BT Broadband using a wired Broadband Extender Flex 500 kit which has served me well, but I understand is no longer available.    I would like to extend the broadband coverage within my old stone house.    Can you please let me know if any of BT's current range of extenders/hotspots would be compatible with the Flex 500, or would you suggest I replace the Flex 500 with something like the BT Mini Wi-Fi Home Hotspot 600 Multi Kit (pack of 3) ?     Many thanks in anticipation.
2 REPLIES 2
Message 2 of 3
Re: Wi-Fi Extenders.
I guess you could either see if you can source extra flex500 hotspots from Ebay or bite the bullet and replace existing setup with the Home Hotspot 600 Multi Kit.
jonwis
Message 3 of 3
Many thanks for your prompt reply Liquorice.     After futher thought, I think I'll just take the replacement option, and try the Mini Wi-Fi Home Hotspot 600 Multi Kit, which will hopefully let me continue with an existing wired connection to my desktop, and allow a wireless connection to my laptop anywhere adjacent to a power socket.
