Grggs9
Message 1 of 3
Wi-Fi discs with sky fibre
Purchased the Bt whole home Wi-Fi 3 discs. I've connected almost all my devices to the Bt WiFi network but these devices are also showing connected to my sky wifi. How is this possible. I used to have the tends nova Wi-Fi cubes and never had this issue. I'm also having diss onnections on sky. I'm wondering if this is causing them. Thanks in advance
2 REPLIES 2
imjolly
Message 2 of 3
Re: Wi-Fi discs with sky fibre
should you not be connecting to your SKY connection not BTWIFI which is slow and unsecured
Oi
Message 3 of 3
Have you switched Wi-Fi off on the sky router ? You can only do this if you are not running sky q or mini box’s. you also need to forget the sky network on ALL devices then they can on;y connect to the new BT disks
