Message 1 of 2
Wi-fi and Ethernet
I want to upgrade/have the best connection I can using my smart hub 2 and x3 Wi-fi discs. If I use the Ethernet port in the discs does this then take away the Wi-fi capability? Or can they run both at the same time. As I don’t want to run Ethernet cables all about from the main hub to devices. If I could use the existing Wi-fi disc layouts and still benefit from the Wi-fi “mesh” or will it be lost.
1 REPLY 1
Message 2 of 2
Re: Wi-fi and Ethernet
@Dan7HouYT
You can use both Wifi and Ethernet together, without any issues.
