United77
Message 1 of 7
WiFi Extenders
Hello All,
Is anyone aware of known issues with the smart hub 2 and the BT WiFi extender 750?
This worked well with my previous HH5, but doesn’t seem to get along with the SH2.
If it’s a compatibility issue is there any benefit in getting the 1200 version or another brand?
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: WiFi Extenders
@United77
Make sure you turn off smart setup, on the SH2.
WiFi extenders are often a waste of time, owing to their poor performance.
United77
Message 3 of 7
Re: WiFi Extenders
Thanks, I will give that a try.
United77
Message 4 of 7
Re: WiFi Extenders
Turning off smart set up didn’t help. It worked for a short time but it’s stopped again.
Does anyone  have any experience of the WiFi hotspot 600 or whole home mini set up with a smart hub 2?
Anonymous
Not applicable
Message 5 of 7
Re: WiFi Extenders
The Hotspot 600 works with my SH2
United77
Message 6 of 7
Re: WiFi Extenders
Thanks. I think I’ll try that.
Anonymous
Not applicable
Message 7 of 7
Re: WiFi Extenders
Be aware that the 600 is 2.4GHz only.
If you decide to go ahead with it, there is an optional cloning feature, the procedure is described in the user manual
