Chrisash916
Newbie
Message 1 of 1
WiFi Home Hotspot 500 power light
Probably an easy one, I have the Home Hotspot 500 system and it was working perfectly. Noticed no internet connection, saw the power light on the main unit connected to the router is off. Yes it's plugged in. Anyone else got a fix or is it goosed? If so, and I but a replacement, can the extender flex be used as an extra extender with a new system?
