Message 1 of 9
WiFi disc not pairing
My WiFi disc is refusing to pair with my Hub. I’ve tried the Ethernet cable. It goes blue but then when I take the Ethernet cable out it sticks on flashing red. I have tried repeating process following a factory reset of the disc. What’s the next step? Thanks
8 REPLIES 8
Message 2 of 9
Re: WiFi disc not pairing
@AndyB14
What colour is the disk, black or white?
Are you using the smart hub 2?
Message 3 of 9
Hi. It’s black, smart hub 2. Thanks
Message 4 of 9
Somewhere on this forum, a troubleshooting guide was posted by one of the device experts, but I cannot find it at the moment.
Probably somewhere on this thread https://community.bt.com/t5/Home-setup-Wi-Fi-network/Introducing-Complete-Wi-Fi-from-BT/m-p/1901302#...
Message 5 of 9
Message 6 of 9
Many thanks. Will work my way through that.
Message 7 of 9
I have tried all that still only flashing blue without cable
Message 8 of 9
Same here, if you are on mode 2 i switched mine to mode 1 and they connect, but my wifi is awful on mode 1
Message 9 of 9
Solved now.  Rang bt, tried all the above.  New disc on way. But.... may be coincidence but worked eventually after Openreach in the street!
