Baaartman
Message 1 of 3
WiFi extender 1200
I have one of these and it was working fine up until a couple of days ago. It is about 18 months old and was bought from the BT shop.
It started 'not extending' and was constantly searching for the hub.
I unplugged it to let it cool down. (it wasn't overly hot, just a little warm but nothing to be concerned about)
I moved it closer to the hub a (HH5) and rest it.
I then tried to connect it to the hubvia WPS (it worked when new).
All that happens now is that the 2 red lights flash (too far and too close) and it won't search at all.
Has anyone got any advice or is it now dead?
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: WiFi extender 1200
Try resetting the home  hub and extender to factory defaults, and start again.
Wireless extenders usually give very poor performance compared to separate hotspot devices.
Baaartman
Message 3 of 3
Thanks. That has done it.
