Message 1 of 4
Wifi 6 support to user devices
I see conflicting information on the extent of wifi 6 support by Whole Home Premium discs. The consumer rights organisation Which UK review says it is supported ONLY between discs and not to the end user device. BT information is not clear. If Which is correct then I'd say BT is deliberately misleading consumers. Can anybody be definitive on this?
3 REPLIES 3
Message 2 of 4
Re: Wifi 6 support to user devices
the BT hubs do not support wifi6
Message 3 of 4
Question was about Whole Home not Hub.
Message 4 of 4
Wi-Fi 6 on the premium discs is reserved for the dedicated Wi-Fi backhaul
