Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
hi
I have just followed the App instructions, disk turned solid blue, I removed the Ethernet cable and the light wet to solid red, it has not changed after 20 minutes.
i reset the new disk, rebooted the hub and tried again, I got the same result, everything seemed fine until I disconnected the Ethernet cable.
I am having the same problem. Initially when I received the 'Smart Hub 2' and 'Wi-Fi Disk' everything set up with ease. However the 'Wi-Fi Disk' disconnected from the network at some point (Nothing has changed from the initial set up, nothing moved, added or changed) and now will not reconnect. I have tried resetting the Disk and starting afresh by connecting directly to the hub using an ethernet cable and the disk responds by turning on a solid blue light after a couple of minutes however when I disconnect the ethernet cable the light turns red and flashes no matter how long I wait. I have gone through the set up procedure multiple times with the same end results. PLEASE HELP!
Hi @Hazel_Davies, I'm sorry to see you're disc isn't connecting to your Hub. If you haven't tried already can you also do a factory reset on the Hub by pressing in the small pinhole button on the back? Let me know how you get on.
@NeilO have reset my hub using the browser based factory reset, and then restored settings from a saved file.
Started the disc setup procedure again, but although light goes from purple to solid blue the advanced settings shows it is not connected. when I remove the Ethernet cable the disc light goes solid red
Image with Ethernet cable connected (light blue)
I was very grateful, 6 pages ago, when you answered my problem.
However now - Months later - I am included on everyone else's cry for help who has my original problem and uses it to piggy-back. Must have been my excellent Subject line 🙂
Is there a way to stop me being included in future?
Thanks & Regards
Bob
@hallsworthbwrote:I was very grateful, 6 pages ago, when you answered my problem.
Thanks & Regards
Bob
Try this for a specific thread:
If you still want to use the forum, but never receive emails when anyone posts in a thread you have contributed to:
Excellent - Thank you.
Did you manage to get anywhere with this?
I'm having the same issues with SH2 and 2 black complete wifi discs. They keep on disconnecting every couple of days - I usually notice in morning when they are flashing red. Usually turning the SH2 off and on will make them re-connect - but this isn't a solution.
I started with 1 disc, which worked without problem since installation for about 6 weeks, and then over the last couple of weeks I've had disconnects every couple of days. I contacted BT and had another disc sent out, and that has the same problem.
It's got to be a firmware / software issue. It's like rebooting the SH2 clears a temporary cache, and when that gets full after a couple of days the discs disconnect again.
I'm at the point of disconnecting them completely since I don't want to be rebooting my SH2 every couple of days.
Another BT issue they seem to be ignoring - or the forum moderators just reel out the old chestnut 'have you tried resetting your hub and discs' - as if that's a solution you can do every couple of days.
My replacement disc has worked well for several months. Last night it stopped and defies all attempts to pair it. The solid blue light goes on for 2 minutes then loses the signal and the red light returns. I have reset the disc to no impact. I rely on the complete home WiFi for work and would appreciate some more timely support than the last time. Thank you.
