cmbellman
Message 1 of 1
Wifi Discs (Black) - connections ignoring
I have one wifi disc in our spare room that was dropping its connection to the main hub and therefore devices just going straight to the hub... I have now connected this via ethernet (power over ethernet) to the main hub and the light is on and signal strong... but despite all this the laptop that is sitting 1ft away and my daughters ipad and phone that she uses in the next room do not connect instead they connect to the hub downstairs which then means the connections are constantly dropping out... I can see the wifi disc in the hub manager and all is well... just has nothing connected to it... I have rebooted the laptop, reset the wifi… told the other devices to forget the network and rejoined but nothing goes to it... I had more luck when it was wifi only rather than ethernet but this just dropped out as the signal between the two was not good enough...
