FC12
Message 1 of 9
Wifi Disk
Hello
I have a smart hub 2 and I am looking into a wifi disk for the upstairs of my home because wifi seems to struggle upstairs.
I am just unsure how this is set up.
I just need one disk.  is it just a case of plugging in to a socket upstairs and that's it?
Does it automatically connect to my hub that's downstairs?
Thanks for help in advance.
8 REPLIES 8
gg30340
Message 2 of 9
Re: Wifi Disk
FC12
Message 3 of 9
Re: Wifi Disk
Thanks but do I need more than one disk? or one disk with the smart hub is fine?
StewM
Guru
Message 4 of 9
Re: Wifi Disk
Hi @FC12 , I have just set this up complete Wi-fi for my daughter. The kit arrived hub and one disc. You follow the instructions and I got a good signal nearly everywhere in the house. Using the MY BT app on my phone there was weaker spot. Phoned up and a second disc is on the way.
I was surprised the coverage that was achievable with just the hub and just one disc.
In your circumstances, it will depend on the make up of your house.
Stew
FC12
Message 5 of 9
Re: Wifi Disk
Cheers Stu.
I have a relatively small home but seem to have a dead spot in my main bedroom, so I’m thinking one disk will be enough.
thanks a lot for your reply.
FC12
Message 6 of 9
Re: Wifi Disk
Hi forgot to ask, do I need a subscription for whole home or I can just buy the disk if I already have a smart hub 2?
Keith_Beddoe
Message 7 of 9
Re: Wifi Disk
To get the complete wifi guarantee and support, you have to pay the monthly extra for the disk.
This thread should help https://community.bt.com/t5/Home-setup-Wi-Fi-network/BT-Complete-Wi-FI-using-Smart-Hub2-amp-Black-Di...
It expensive, and you will find a much cheaper way to extend the range of your wifi, like the BT home hotspot.
https://shop.bt.com/mini-sites/connected-home/home-hotspots/
£49.99 or less if you shop around.
StewM
Guru
Message 8 of 9
Re: Wifi Disk
I suppose you can buy an extra disc yourself, but I don’t think you get the full Wi-fi guarantee. Which may help if you need more than one disc.
My daughter upgraded to the Total Wi-fi package. They had tried to use Wi-fi extenders etc, but they couldn’t get them to work properly. She was spending quite a bit on extra data for her mobile as her and grandsons bedroom had no Wi-fi. So now they have chromecast on their tv and actually save money.
Stew
FC12
Message 9 of 9
Re: Wifi Disk
Thanks again
