My BT Wholehome app shows an excellent reception but my iphone 6 only shows 2 bars for wifi reception. Any ideas why this should be?
Solved! Go to Solution.
Stays the same.
The bars are pretty meaningless. If you want to know the signal strength you should get a wifi analyser. Are you getting the speeds you would expect on your phone. If so I wouldn't worry about it.
