alan_mc
Message 1 of 5
Wifi disc location
Ok, going slightly mad. I have complete wifi and in process of setting up additional disc, I follow the steps, locator tells me position is excellent, i switch on disc, go through rest of the steps and complete. Then every time, the bt app then says good not excellent. Any ideas ???? Doesn't matter what i put it, this happens every time
4 REPLIES 4
Message 2 of 5
Re: Wifi disc location
Re the Bt app. Presumably it’s the MyBt app.
Which device are you using. Is it Android or iPhone / iPad.?
For iOS  version, sometimes it helps to clear the cache from that app, and start again. You will find this option on the iOS settings.
It seems to be a strange solution, but sometimes it works.....don’t know why.
alan_mc
Message 3 of 5
Android version.
Message 4 of 5
@alan_mc wrote:
Android version.
For the Android device the best indication of signal strength is obtained using an app.
There’s an app Network Signal Info Pro.
There’s a free version and a paid version, which is better.
It gives reasonably accurate indications of signal strength (plus other data on mobile signals). You can move around your house and check wi-fi signal strength in dB. This is a better indication than “strong”, “poor”, “excellent”.
The important indication is the signal strength near to your device, e.g computer, if it’s stationary.
alan_mc
Message 5 of 5
Many thanks
