Message 1 of 2
Wifi extenders
Do the extender 600 just work off ethernet connection or wifi  and do they have to be on the same ring main as the router as I cant seem to be able to get an extended signal
1 REPLY 1
Message 2 of 2
Re: Wifi extenders
Are you talking about a wifi extender, which is a single device which is simply a repeater for the wifi signal, or are you talking about a pair of broadband extenders (a.k.a powerline adaptors). If the former, as stated they are purely a wifi repeater and can be plugged in anywhere within wifi range of the hub and distant location. The latter possibly need to have both the extenders on the same ring main, but have been known to work across rings, but must definitely be on the same consumer unit.
