Ognats1
Message 1 of 8
Wifi
Hi can anyone give me some advice I have recently  joined  BT and my hub is in the kitchen as no socket in the living  room  for it but I can not get connected I suspect it's too far away is there a booster I can get as I have an other phone socket in the hallway I could plug one in .
7 REPLIES 7
imjolly
Message 2 of 8
Re: Wifi
have you turned off smart setup as that often causes problems
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
lnajr02
Recognised Expert
Message 3 of 8
Re: Wifi
What distance are you from the HUB and can you see the WiFi SSID (WiFi Name) in your PC or device setup when you are looking to connect? also What type of internet are looking for just internet shopping, TV Streaming or Play station type activity ?
Ognats1
Message 4 of 8
Re: Wifi
Just Internet my hub is about 20m away from my living room in the kitchen
lnajr02
Recognised Expert
Message 5 of 8
Re: Wifi
That's a large Home , can you see the WiFi signal in both rooms , if Yes how many bars, the other option would to look at something like the BT WiFi Extender 1200 (£49) or the BT Whole Home WiFi system one of three depending on the speed and budget.
Ognats1
Message 6 of 8
Re: Wifi
ManyThanks will look into that
licquorice
Message 7 of 8
Re: Wifi
imjolly
Message 8 of 8
Re: Wifi
where is you master socket - the one after the openreach cable enters your home?
does the kitchen socket have 2 outlets for broadband and phone or just the one?
