Message 1 of 4
Wired diagram
Hi
I pulled the wires out of the back of my WiFi hub so have no internet, my hub is flashing orange at the moment.
I can't remember which wire goes where, does anyone have a diagram please so I can get it back on.
3 REPLIES 3
Message 2 of 4
Re: Wired diagram
Does the info here help?
Message 3 of 4
Re: Wired diagram
Hi
Thanks but I'm beginning to think it's a connection problem and not the wires itself.
I'm going to phone BT and check with them, thanks for your help
Anonymous
Not applicable
Message 4 of 4
Re: Wired diagram
Do you have FTTP, provided via an ONT with three LEDs on it, or a copper based service with a standard telephone socket?
If the former, you need an ethernet cable between the ONT & LAN 4 on the Hub.
If the latter there will be a slightly smaller connector, usually grey that connects to the telephone socket.
