Bern45
Message 1 of 3
broadband extender 600
I bought a broadband extender Flex 600 Kit. a few weeks agoe. It as been working well, now it is not working. One of the units the power light is not on.  Is it faulty?
2 REPLIES 2
CJT80
Recognised Expert
Message 2 of 3
Re: broadband extender 600
Hello @Bern45
If the powelight is off, either the socket the extender is plugged into has an issue (you can test that by plugging something else in the socket) or most likely the extender is not working.
Any more info, try here: http://bt.custhelp.com/app/answers/detail/a_id/55087/~/broadband-extender-600
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Bern45
Message 3 of 3
The the unit is faulty. Thank you.
