bazal
Message 1 of 4
broadband fault
reported a broadband fault 31/07/2019 and recieved a number :- VOL013 but unable to find it in track a fault ?.can any body advise where to look to find out what is going on
3 REPLIES 3
Message 2 of 4
Re: broadband fault
did you go to BT help and then use fault tracker
is it a broadband fault or a phone fault?  do you have a dial tone from the test socket?  if not then it's a phone fault not broadband
bazal
Message 3 of 4
Re: broadband fault
yes I did but only showed other problems that have been solved but not this one at all
Message 4 of 4
Re: broadband fault
for your security delete fault ref as public forum
