Chrissie-T
Newbie
Message 1 of 2
bt 4600 unable to register second hand base, blank screen
My sister gave me a bt4600 as she bought a different by phone as she didn’t like it. It is less than 2 years old I think. I needed a 2nd handset and so purchased one through Amazon. Cannot remember ever registering it with the base unit as Handset2 and seem to be unable to do so now as there is a blank screen. I have no menu etc., and wanted to store numbers.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: bt 4600 unable to register second hand base, blank screen
Hi @Chrissie-T,
Thanks for your post and welcome to the Community.
Sorry to see you're having problems using the BT4600 handset(s).  You'll need to speak with product support for the best advice to answer your question.  Here is the link >> BT4600 Product support <<
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
