Djandyk
Message 1 of 2
bt 8500
Hi i’m having with bt 8500 it seems to not hang up properly leaving the line engaged the only way i can get it to end is to pull the lead out the sockets to get the dial tone back any ideas tried resetting the base
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: bt 8500
Hi @Djandyk  welcome to the forum and thanks for posting. Sorry you are having a fault with your BT 8500 phone. Check out the BT8500 help page and the contact details for the product helpdesk are listed if you are still experiencing this fault.
Cheers
John
