abbeyroad
Message 1 of 5
bt admin password
hi
i have a bt smart hub and the admin password is not accepted, keeps saying incorrect password
please could someone advise me on what i need to do
many thanks
4 REPLIES 4
Message 2 of 5
Re: bt admin password
Reset it to factory default.
abbeyroad
Message 3 of 5
Ok thanks
ill give it a go
Moderator
Moderator
Message 4 of 5
Hi @abbeyroad,
Did you get a chance to reset it?
Let me know how you got on.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
abbeyroad
Message 5 of 5
Yes i reset the router and it accepted the password
thanks for your advice
