Message 1 of 2
bt home wifi (3 nodes) one is connected to a switch (issues of no internet and disconnected error)
I have 3 nodes - one is set up to the router (upstairs)
the other is in the kitchen
the other is in the lounge - this is connected to a switch by the ethernet port.  now when i connect devices to the switch, there is one in particular my QNAP NAS - it brings up an disconnected issue on the app.  when i unplug/restart the lounge bt node and remove the ethernet - its fires back up as normal.  the ethernet does work on the switch, as i have a few things which show my cctv and my denon avr - its when i add the NAS device - it seems to crash the system
is there a limitation on devices that can be connected via ethernet to a node? is it my nas?
can someone help me figure this out please?
thank you
1 REPLY 1
Message 2 of 2
Re: bt home wifi (3 nodes) one is connected to a switch (issues of no internet and disconnected erro
I.P conflict? Is your NAS set to Static or Dynamic?
