Hi, I recently purchased 4 new whole home wifi mini discs. Three came in one box with the same admin and wifi codes. The other has different codes for wifi and admin. I've tried connected the 4th but failed. How do I change details on the 4th disc to link with the other 3? thanks for any feedback.
Hi stevephillips,
Hopefully you may have already resolved your issued. If not I will share some advice to get you up and running.
Once you've used the Whole Home Wi-Fi app to setup the first 3 discs, you'll be able to use the App to 'Add another disc'.
This option is under Settings -> Add another disc
The app will guide you through the process to add the 4th disc, in brief this will be:
This should get you up and running with all 4 discs and using the same Wi-Fi and Admin credentials as the 3-disc kit.
Many thanks
Darren_B
