Hi,
Just recieved home wifi kit and getting" no response from your network" on setting up the first disc on the app. not what i expect considering the price of this!!!!! Any suggestions apart from sending it back
Have you tried a reboot of the router, let it settle and then try setting up again? Or perhaps delete and reinstall the app and see if that allows you to make progress.
Hi,
Thanks for the reply, managed to get it going, issue was the app on the iphone. when i loaded it on my ipad it seemed to work.
Great, glad you got it sorted.
