Message 1 of 5
can i re code a BT Graphite 2500 handset to another base unit.
Hi,bought a s/hand set of  2graphite 2500 phones,1base & extra, can i re register the fresh handsets to my orginal base unit,
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: can i re code a BT Graphite 2500 handset to another base unit.
Should be possible to deregister & then reregister. See p.65:
https://shop.bt.com/content/uni2/documentation/8h34/bt2500_user_guide_[ed.3].pdf
Are the original phones the same model? If not then you may only have basic functionality with the 2500s.
Message 3 of 5
psu looks different but phones and cables look the same.
Message 4 of 5
Hi,rbz5416   many thanks for your reply & link,great help.
thanks again tillyg
Message 5 of 5
Hi, many thanks managed to re register a handset to my  system took a few go`s but go there, have saved the full manual to my pc for future use,
