pbwpu
Message 1 of 1
can you run 2 bridges off a br home hub 6
Can the HH6 run 2 wifi bridges? I friends desires to do that but another says they''ve had trouble with connetion drops with that configuration and hh6. Is this a known issue.? Can't see why it would be as presumably as many repeaters as you like can be added
(Also anyone tested the relative strenght of the BT mesh dics -v- the hh6 in penetration of thinck walls (I presume the disc has fewer ariels and a weaker signal on its own - the gain being only the range by bounching from disc to disc.)
