spiderwebby
Message 1 of 8
change BT mini hub's IP address
How do I change the gateway IP address of a BT minihub?
It defaults to 192.168.1.1 which clashes with my existing network.
Disconnecting this network isn't an option, I've got kit on my LAN that I need to access. (+ I don't want to re-address 15ish servers to work around this)
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: change BT mini hub's IP address
@spiderwebby
There is a BT help page here http://bt.custhelp.com/app/answers/detail/a_id/56591
To change the settings on the BT Mini Hub you need to use the Mini Hub Manager.
  1. Open a new web browser on a device connected to your BT Mini Hub and type minihub.home in the address bar. This will open the Mini Hub Manager
  2. Enter the Admin password. You'll find the default password on the settings card on the back of your Mini Hub
  3. You can then access and make changes to your settings
spiderwebby
Message 3 of 8
The help page says nothing about changing the device IP and there are no options that allow you to change the IP from the admin page.
The answer to my question won't be on the standard reply sheet.
imjolly
Message 4 of 8
are you currently a BT. Broadband customer?
spiderwebby
Message 5 of 8
Archiee
Message 6 of 8
just go to  http://minihub.wifi/index.html#/lanSettings
to open hidden settings page 🙂
Tags (1)
licquorice
Message 7 of 8
I think after almost 2 years, the OP has probably figured it out 😁
spiderwebby
Message 8 of 8
OP gave up and moved to virgin media 😛
