Message 1 of 2
disable management login over wifi
Hi there,
Is there a way to disable login to the management interface over wifi?  So only connect to the managment page via ethernet on the back of the BT Hub? ( I have a BT Hub2)
1 REPLY 1
Message 2 of 2
Re: disable management login over wifi
No
