ingermorris
Message 1 of 3
extender discs
In the past I have set up two discs. I am trying to set the third one up months later but can't even get the light on. Any suggestions? thanks
2 REPLIES 2
MurrayB
BT Devices Expert
BT Devices Expert
Message 2 of 3
Re: extender discs
Hi ingermorris,
Which set of discs do you currently have, and what type of disc are you liking to add as a third?
Additionally, have you tried to swap the PSU with one that you know works, in case there is an issue with the power supply itself?
ingermorris
Message 3 of 3
Re: extender discs
Thank you for replying. O I was too nervous to detach the two that do work. What I have done now is sign up to Halo 2 which activates tomorrow I can then book the BT man to come and see to the internet in the house. Let's see what he suggests. As soon as anything goes wrong with the internet I just go into a meltdown and can not cope with it........I am not techie and trying to work from home and then hubby goes into a strop when he can't use his laptop to look at cars on e-bay and the Sonos won't work in the kitchen. Thanks.
