casaschi
Message 1 of 3
hybrid connect lights off
Hello, just activated my hybrid connect device, all good. I read somewhere that's possible to switch the device lights off (similarly to what it's possible to do with the smart hub 2) but I could not find any such setting; I looked in the smart hub 2 web manager and in the My BT app on my phone but no such configuration setting is available.
My hybrid connect is on firmware version v0.11.04.202107211837-BT while my smart hub 2 is on firmware version v0.27.07.07281-BT.
Where should I look to switch the hybrid connect lights off?
Thanks.
2 REPLIES 2
andrew_cliff
Message 2 of 3
Re: hybrid connect lights off
This facility is not currently available
graywallis
Message 3 of 3
It would be nice to be able to dim the lights, as a suggestion to the developers.
